Having been busy with other (paid) projects, I did not have much time tinkering with the adventure engine for some time. I did experiment with the <canvas> some more and that yielded some interesting results.
But in the meanwhile, I thought perhaps putting this out there is the right thing to do at this point in time. So here you have it !
If you want to look at something, press the L key and to pick something up, press the P key. If you get stuck, you can move the character around with the arrow keys.
There are some test functions available like the filter mode, fades and testing a part of the scripting functions.
Nothing is obfuscated and you can download all the files with any extraction tool to have a go at it yourself. Apart from the "borrowed" graphic asset, all material/code is to be considered under the MIT license (version 2.0).
If anybody wants a zip file, let me know.
Timescale
