K.C. Lee referred me to the MAX44284, which was helpful. Its specs were close to those of the MAX9923F that I was looking at, but it smaller and almost half the price at scale!
v offset
i bias
gain error
CMRR
Vo min
$pk
MAX44284
20.5uV
80nA
0.15%
145db
1mV-20mV
1.19
MAX9923F
10uV
1pA
.5%
140db
10mV
2.1
Maxim also offers a spice model of the MAX44284f on their website, so I set up a simulation just to confirm the problem I noticed the other day.
You could have a 40uA+ constant current sink to put the current sense in the linear region. All you have to do is to subtract that amount in the firmware as part of the calibration process.
The other thing is that if your instrument have its independent battery), then you could just float the whole circuit for positive rail sensing. Use ground sensing (relative to the instrument) directly with a high resolution ADC so you don't even deal with opamp.
