If you look closely at the Pink LED you'll notice it has a slightly different footprint and is labeled "Purple RGB". This is because originally I had intended for it to be a RGB with fixed value resistors so that it'd be Purple instead of pink. The reason it's a solid Pink LED instead is because I mistakenly placed the 47ohm resistor on the Anode side instead of Cathode, as a result the RGB LED couldn't get enough power to display the correct color. Thankfully the foot print was close enough to the single color LED for me to use a Pink LED as a drop in replacement.
When I release the Gerbers for this SAO it will be different from what I made originally so as to fix this mistake and will have fewer resistors.
Michael
MagicWolfi
Mirko
