AnalogWatch is now booting
A project log for (BCD)WristWatch
It all started with the idea of a PCB which could display the time in BCD code....
sulkithsulkith 10/04/2020 at 13:110 Comments
i found the short circuit, i mixed up a 0Ohm Resistor with a Capacitor.
After removing this capacitor it was possible to program the Watch. Sadly i noticed, that the BMA is not working....
Seems like i might have killed it by soldering it to hot and/or to long.
So the next Todo is to build a Soldering rig, where i can solder these little chips reproducible.
