Connecting the XBox One Controller via Bluetooth
A project log for Robot spider w/ 9g Servos
I built a robot spider using 16 9g Servos. It is controlled by an XBox One Controller via Bluetooth.
max-felix-mllerMax-Felix Müller 05/03/2019 at 20:410 Comments
What a journey!
Who would have guessed how hard it could be to connect a bluetooth device?
Turn the controller on, go into pair mode, search it on the raspberry and connect. Done, isn't it?
Well no, it isn't.
Different error messages are popping up. Some mentioning an IO problem, sometimes it's a unknown device etc.
I can't quite explain why but it has to do with some security check of the bluetooth module that has to be disabled.
Here's how I disabled it and got my controller to work properly:
To do the bluetooth settings automatically on startup, do the following:
1. In your terminal, enter:
sudo nano /etc/rc.local
2. Beneath everything else but before “exit 0”, enter the follwing, but take care to also copy the ‘’ around the later part of the second command:
sleep 10
sudo bash -c 'echo Y > /sys/module/bluetooth/parameters/disable_ertm'
3. Save and quit Nano
4. Reboot to test and confirm (check if the modified file is correct)
What exactly are you doing there?
  1. You enter a text editor in the terminal called Nano. You open the file rc.local which is run on startup
  2. After all the other startup tasks, you put the new command. After a short delay it writes a ‘Y’ in the file disable_ertm. To do it you have to issue the command via bash to get root permissions. ERTM will then be disabled.
  3. Saves the rc.local file.
  4. Reboots and then runs rc.local file automatically.
If you did everything right your XBox controller should now connect and be accepted as an input device. You can check the functionality using this example code from pygame:
import pygame
# Define some colors
BLACK    = (   0,   0,   0)
WHITE    = ( 255, 255, 255)
# This is a simple class that will help us print to the screen
# It has nothing to do with the joysticks, just outputting the
# information.
class TextPrint:
    def __init__(self):
        self.reset()
        self.font = pygame.font.Font(None, 20)
    def print(self, screen, textString):
        textBitmap = self.font.render(textString, True, BLACK)
        screen.blit(textBitmap, [self.x, self.y])
        self.y += self.line_height
    def reset(self):
        self.x = 10
        self.y = 10
        self.line_height = 15
    def indent(self):
        self.x += 10
    def unindent(self):
        self.x -= 10
pygame.init()
# Set the width and height of the screen [width,height]
size = [500, 700]
screen = pygame.display.set_mode(size)
pygame.display.set_caption("My Game")
#Loop until the user clicks the close button.
done = False
# Used to manage how fast the screen updates
clock = pygame.time.Clock()
# Initialize the joysticks
pygame.joystick.init()
# Get ready to print
textPrint = TextPrint()
# -------- Main Program Loop -----------
while done==False:
    # EVENT PROCESSING STEP
    for event in pygame.event.get(): # User did something
        if event.type == pygame.QUIT: # If user clicked close
            done=True # Flag that we are done so we exit this loop
        # Possible joystick actions: JOYAXISMOTION JOYBALLMOTION JOYBUTTONDOWN JOYBUTTONUP JOYHATMOTION
        if event.type == pygame.JOYBUTTONDOWN:
            print("Joystick button pressed.")
        if event.type == pygame.JOYBUTTONUP:
            print("Joystick button released.")
    # DRAWING STEP
    # First, clear the screen to white. Don't put other drawing commands
    # above this, or they will be erased with this command.
    screen.fill(WHITE)
    textPrint.reset()
    # Get count of joysticks
    joystick_count = pygame.joystick.get_count()
    textPrint.print(screen, "Number of joysticks: {}".format(joystick_count) )
    textPrint.indent()
    # For each joystick:
    for i in range(joystick_count):
        joystick = pygame.joystick.Joystick(i)
        joystick.init()
        textPrint.print(screen, "Joystick {}".format(i) )
        textPrint.indent()
        # Get the name from the OS for the controller/joystick
        name = joystick.get_name()
        textPrint.print(screen, "Joystick name: {}".format(name) )
        # Usually axis run in pairs, up/down for one, and left/right for
        # the other.
        axes = joystick.get_numaxes()
        textPrint.print(screen, "Number of axes: {}".format(axes) )
        textPrint.indent()
        for i in range( axes ):
            axis = joystick.get_axis( i )
            textPrint.print(screen, "Axis {} value: {:>6.3f}".format(i, axis) )
        textPrint.unindent()
        buttons = joystick.get_numbuttons()
        textPrint.print(screen, "Number of buttons: {}".format(buttons) )
        textPrint.indent()
        for i in range( buttons ):
            button = joystick.get_button( i )
            textPrint.print(screen, "Button {:>2} value: {}".format(i,button) )
        # Hat switch. All or nothing for direction, not like joysticks.
        # Value comes back in an array.
        hats = joystick.get_numhats()
        textPrint.print(screen, "Number of hats: {}".format(hats) )
        textPrint.indent()
        for i in range( hats ):
            hat = joystick.get_hat( i )
            textPrint.print(screen, "Hat {} value: {}".format(i, str(hat)) )
    # ALL CODE TO DRAW SHOULD GO ABOVE THIS COMMENT
    # Go ahead and update the screen with what we've drawn.
    pygame.display.flip()
    # Limit to 20 frames per second
    clock.tick(20)
# Close the window and quit.
# If you forget this line, the program will 'hang'
# on exit if running from IDLE.
pygame.quit ()
Rich text editor
