from machine import Pin, TouchPad, PWM, ADC
import time
import urandom as random
led_pins = [32, 33, 25, 26]
touch_pad_pins = [15, 14, 13, 12]
speaker_pin = Pin(27)
volume_level = 20
frequencies = [209, 252, 310, 415]
leds = []
touch_pads = []
untouched_values = []
on = 0
off = 1
simon = []
def set_led(index, on_or_off):
leds[index].value(on_or_off)
def set_all_leds(on_or_off):
for i in range(4):
set_led(i, on_or_off)
def setup_leds():
for pinNumber in led_pins:
leds.append(Pin(pinNumber, Pin.OUT))
print("led pins are {}".format(leds))
def setup_touch_pads():
for touch_pad_pin_number in touch_pad_pins:
touch_pads.append(TouchPad(Pin(touch_pad_pin_number)))
print("touch pads are {}".format(touch_pads))
def read_touch_pads():
touch_values = []
for index in range(4):
touch_values.append(touch_pads[index].read())
return touch_values
def calibrate_touch_pads():
n_times = 3
total = [0, 0, 0, 0]
average = [0, 0, 0, 0]
for i in range(n_times):
touch_values = read_touch_pads()
total[index] += touch_values[index]
average[index] = total[index] / n_times
global untouched_values
untouched_values = average
print("untouched_values are {}".format(untouched_values))
def indicate_game_over():
set_all_leds(on)
play_game_over_tone()
def play_tone(index):
PWM(speaker_pin, freq=frequencies[index], duty=volume_level)
def stop_tone():
p = PWM(speaker_pin)
p.deinit()
def play_game_over_tone():
p = PWM(speaker_pin, freq=100, duty=volume_level)
time.sleep(1)
p.deinit()
def simon_says():
for num in simon:
time.sleep(.5)
print("Simon says {}".format(num))
set_led(num, on)
play_tone(num)
time.sleep(.5)
stop_tone()
set_led(num, off)
def wait_for_button_press():
while True:
is_touched = touch_values[index] < untouched_values[index] * 3 / 4
if is_touched:
print("Human pressed {}".format(index))
return index
return -1
def human_says():
for num in simon:
print("Simon expects {}".format(num))
button_pressed = wait_for_button_press()
set_led(button_pressed, on)
print("Simon said {}, Human said {}".format(num, button_pressed))
if button_pressed == num:
print("Good job human!")
play_tone(button_pressed)
time.sleep(0.5)
stop_tone()
set_led(button_pressed, off)
else:
print("BAD HUMAN! GAME OVER!")
return True
return False
def init_random_seed():
a = ADC(Pin(34))
s = 0
while s == 0:
s = a.read()
time.sleep(0.1)
random.seed(s)
def play():
global simon
simon = []
game_over = False
while not game_over:
new_number = random.randint(0, 3)
print("\nSimon picked a new number: {}".format(new_number))
simon.append(new_number)
print("Simon sequence is now: {}".format(simon))
simon_says()
game_over = human_says()
def wait_for_game_start():
set_all_leds(on)
set_all_leds(off)
def loop():
while True:
play()
def main():
print("main starts...")
init_random_seed()
setup_leds()
setup_touch_pads()
loop()
print("Main imported!!")
main()
