Seeing Sierpinski Triangle on Facebook inspired me to try it on my tiny OLED.
import machine, ssd1306, math, time
from machine import Pin
def toInt(a):
return [int(a[0]), int(a[1])]
def toMid(a, b):
return [(b[0]+a[0])/2, (b[1]+a[1])/2]
class Sierpinski3:
isWemosD1Mini = True
xMax = 64 if isWemosD1Mini else 128
yMax = 48 if isWemosD1Mini else 64
sclPin = 5 if isWemosD1Mini else 18
sdaPin = 4 if isWemosD1Mini else 21
x0 = xMax / 2
y0 = yMax / 2
def oledSetup(self):
i2c = machine.I2C(scl=Pin(self.sclPin), sda=Pin(self.sdaPin))
return ssd1306.SSD1306_I2C(self.xMax, self.yMax, i2c)
def plot(self, oled, a, b, c):
p = toInt(a)
q = toInt(b)
r = toInt(c)
oled.line(p[0], self.yMax-1-p[1], q[0], self.yMax-1-q[1], 1)
oled.line(q[0], self.yMax-1-q[1], r[0], self.yMax-1-r[1], 1)
oled.line(r[0], self.yMax-1-r[1], p[0], self.yMax-1-p[1], 1)
def fillTriangle(self, oled, bottomLeft, width):
if width>8:
bottomRight = [bottomLeft[0] + width, bottomLeft[1]]
half = width / 2
y = bottomLeft[1] + math.sqrt(width**2 - half**2)
top = [bottomLeft[0] + width/2, y]
mid1 = toMid(bottomLeft, top)
mid2 = toMid(bottomRight, top)
mid3 = toMid(bottomLeft, bottomRight)
self.plot(oled, mid1, mid2, mid3)
self.fillTriangle(oled, bottomLeft, half) # bottom left triangle
self.fillTriangle(oled, mid3, half) # bottom right triangle
self.fillTriangle(oled, mid1, half) # top triangle
def drawFrame(self, oled, half):
oled.fill(0)
width = half * 2
bottomLeft = [self.x0 - half, self.y0 - half]
bottomRight = [self.x0 + half, bottomLeft[1]]
top = [self.x0, bottomLeft[1] + math.sqrt(width ** 2 - half ** 2)]
# Draw the first one special
self.plot(oled, bottomLeft, bottomRight, top)
# Draw the remaining recursively
self.fillTriangle(oled, bottomLeft, width)
oled.show()
def main(self):
oled = self.oledSetup()
while True:
slop = 5
for half in range(0, self.y0+slop, 3):
self.drawFrame(oled, half)
time.sleep(0.2)
for half in range(self.y0+slop-3,0,-3):
instance = Sierpinski3()
instance.main()
