Here's a video from 2014. It shows the CFT running its first ever program—and without the ALU at that, since I wasn't yet testing that part.
Everything was still makeshift at this stage.
The video demostrates:
- A simple program toggled in using the front panel.
- Listing and disassembling the program via the DFP (remote control debugging/testing subsystem—this runs on a microcontroller). The DFP is the big board closest to the camera.
- The program is then executed using the front panel.
The CFT doesn't need the ALU to increment registers, so a simple counter program that also triggers a ‘test success’ message is easily possible and shows off everything but the ALU.
