I can totally relate to that! A good way to manage unnecessary spending is to use a virtual card service like https://linkpay.io/. With it, you can easily generate temporary virtual cards that you can turn off anytime. This way, if you know that most of your spending happens after a certain time, you can just disable the card in advance and avoid those impulse purchases. It's a flexible solution that puts you in control of your finances, no matter the time of day!
