After some fiddeling around with pygame.image I got this to work.
I use pygame because I though I knew how to display an iamge there. It turns out I didn't. Well at least now I guess I do.
Later on I will propably switch to a different gui library. I'm thinking of Tkinter.
And here is the code:from matplotlib import mlab as mlab
from rtlsdr import RtlSdr
import numpy as np
from PIL import Image
import time
import pygame
DISPLAY_WIDTH = 256
DISPLAY_HEIGHT = 200
sdr = RtlSdr()
# configure device
sdr.sample_rate = 2.4e6 # Hz
sdr.center_freq = 94.7e6 # Hz
sdr.freq_correction = 60 # PPM
sdr.gain = 'auto'
image = []
def get_data():
samples = sdr.read_samples(16*1024)
power, _ = mlab.psd(samples, NFFT=1024, Fs=sdr.sample_rate /
1e6)
max_pow = 0
min_pow = 10
# search whole data set for maximum and minimum value
for dat in power:
if dat > max_pow:
max_pow = dat
elif dat < min_pow:
min_pow = dat
# update image data
imagelist = []
for dat in power:
imagelist.append(mymap(dat, min_pow, max_pow, 0, 255))
image.append(imagelist[round(len(
imagelist)/2)-round(len(imagelist)/8): round(len(imagelist)/2)+round(len(imagelist)/8)])
if len(image) > 200:
image.pop(0)
def mymap(x, in_min, in_max, out_min, out_max):
return int((x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min)
pygame.init()
gameDisplay = pygame.display.set_mode((DISPLAY_WIDTH, DISPLAY_HEIGHT))
pygame.display.set_caption(f"DIY SDR")
clock = pygame.time.Clock()
background = pygame.Surface(gameDisplay.get_size())
background = background.convert()
background.fill((0, 0, 0))
game_quit = False
while not game_quit:
gameDisplay.blit(background, (0, 0))
for event in pygame.event.get():
if event.type == pygame.QUIT:
game_quit = True
get_data()
outimage = np.array(image, np.ubyte)
outimage = Image.fromarray(outimage, mode='L')
outimage = outimage.convert('RGBA')
strFormat = 'RGBA'
raw_str = outimage.tobytes("raw", strFormat)
surface = pygame.image.fromstring(raw_str, outimage.size, 'RGBA')
gameDisplay.blit(surface, (0, 0))
pygame.display.update()
clock.tick(60)
pygame.quit()
try:
pass
except KeyboardInterrupt:
pass
finally:
sdr.close()
