Boards are assembled using small, 0604 red LEDs as that's what I had on hand. Pics:
Assembly
Front illuminated
External
The test worked well as far as illumination, however, I don't believe the LEDs I'm using can light up an area this large. This test would work better with smaller illuminated areas.
