Boards are assembled using small, 0604 red LEDs as that's what I had on hand. Pics:
Assembly
![](https://cdn.hackaday.io/images/8861521558822028452.jpg)
![](https://cdn.hackaday.io/images/8917581558822028582.jpg)
![](https://cdn.hackaday.io/images/9640541558822028622.jpg)
Front illuminated
![](https://cdn.hackaday.io/images/6818271558822047321.jpg)
![](https://cdn.hackaday.io/images/2766981558822047320.jpg)
![](https://cdn.hackaday.io/images/909261558822047359.jpg)
External
![](https://cdn.hackaday.io/images/1521801558822062655.jpg)
![](https://cdn.hackaday.io/images/5268621558822062640.jpg)
![](https://cdn.hackaday.io/images/2689291558822062657.jpg)
The test worked well as far as illumination, however, I don't believe the LEDs I'm using can light up an area this large. This test would work better with smaller illuminated areas.
