T5 Profile
I started with the T5 pulley and belt profile because I need a large tooth to suit CNC machining. But recently I found that the GT2 profile can be drilled with a 1.3 mm diameter bit. Sure the outside perimeter still need to be cut. So I will reconsider the pulley and belt profile later.
Here is the 12 tooth pulley and belt profile that I coded:
The belt is wrapped around the pulley (the red circle is the pitch circle).
Note how loose the fit is! This appears to be part of the design feature:
Other belt profiles (GT2) have lower backlash and should be considered later.
Here is T5 belt profile:
and the pulley profile:
And here is the design:
Here are the calculations:
Cog and Belt Design | T5 |
Pitch | 5.000 | mm |
Z1 | 12 | t |
Z2 | 60 | t |
Z1 Pitch Diameter | 19.249 | mm |
Z2 Pitch Diameter | 95.643 | mm |
Pitch Centre (meshed) | 57.446 | mm |
Offset | 17.868 | mm |
Cog Centres | 75.314 | mm |
Belt Length | 350.000 | mm |
Belt Teeth | 70.0 |
Z1 Outside Diameter | 18.249 |
Z2 Outside Diameter | 94.643 |
I will upload the spreadsheet to the file area.
AlanX
