Today is the big day--I prepared to (from a distance) connect 9000 charged farads (8.1 volts) to 1050 partially discharged farads (3.5 volts).
![](https://cdn.hackaday.io/images/4205961558381126767.jpg)
Nothing spectacular to report--probably got enough charge (in ten seconds) to run for 20 minutes.
Peak current during the transfer was around 45 amps and the hottest physical component (plug connector, #18 wire) reached 122 degrees F. The wiring and the connector represent about .1 ohm, so that resistance limits the transfer.
To charge Little Flash in one second, I would need to transfer about 400 amps. The connector and wire size to accomplish that (for a one pound robot) seem impractical--so I'll be happy with a ten second charge for now.
Probably the supercap has significant internal resistance too.
Resistance leads to heating, heating leads to the electrolyte boiling, and electrolyte boiling leads to explosions. This is the path to the dark side. :)
More perfectly good capacitors than I care to admit have met their demise at my hands. You think a gunshot is loud? Trying overloading a supercap..
