While I wait for my DFRobot boards to arrive from China I'm going to work on the menu first.
I have a few Arduino Nano boards kicking around; it's breadboard-friendly pin layout is perfect for prototyping. I also have an lcd display and a rotary encoder already, so I can attach those to the breadboard with some male-female jumper cables.
This little setup will enable me to work on the menu and selecting/setting the parameters, and also committing the parameters to EEPROM so they can be loaded on startup.
I have also ordered a little DFRobot mp3 module for this setup, which, when it arrives, will allow me to test reading data and playing sound from it's onboard Micro SD Card slot.
Good times!
Craig Hissett
