Research project that may eventually become a product.
Reflow oven made from scratch for small-scale electronics workshops, that may be expanded later for larger scales.
The goal is to be able to control the whole construction of the oven, from the heating elements to the materials for the box and so on. This means to choose the right elements that are easily available and work in the most effective way.
The research is focused on the creation of the heating and heat protection for the electronics of the oven. Also, a high quality soldering is a **must**.
