See: Introducing the Raspberry Pi Zero
Mounting
- 4x M2.5 mounting holes
- Centres - width 58mm, depth 22mm
- Holes drilled to 2.75 +/- 0.05mm
Connector
- Header 40 pin
- Centred between two mounting holes.
- Centre at 29mm from mounting hole.
A project log for Cosmic Array
An array of cosmic ray detectors across a landscape that demonstrates in light and sound how cosmic rays are constantly all around us.
Mounting
Connector
