Upgrading a Cosmic Array detector element for standalone use.
A project log for Cosmic Array
An array of cosmic ray detectors across a landscape that demonstrates in light and sound how cosmic rays are constantly all around us.
robert-hartRobert Hart • 01/28/2018 at 04:06•0 Comments
Recently I upgraded a Cosmic Array detector element for standalone use. This includes replacing the Raspberry Pi Zero W with a full Raspberry Pi 3B for faster processing speed and improved audio.
Original unit used in Cosmic Array installation.
Wiring was improved to reduce noise and GMT cables were replaced with HV Teflon coated RG178 coax to reduce false muon counts. With the addition of external connectors for access to electronics including RPi3 USB, LED Driver, DC Power and direct Audio out from RPi3.
Inside unit with upgrades
Operating detector with upgrades
In the original concept of this detector I planned to drive acoustic instruments from the output of the detector. But due to budget and time constraints a raspberry pi zero w was chosen to play wave files. Consequently it is design to drive solenoids or contractors directly.  This modification allows the user to  drive anything from large gones to glockenspiel to other electronic or midi devices.
Note each LED output driver pulls low to 0V/Ground.
