Boards arrived over the weekend but I haven't had time to solder them up. They look absolutely wonderful in the new @oshpark After Dark solder mask option.
I also decided this fit well into the Connect World contest going on so I entered it, though at this point I'm not sure how much I'll actually be able to put in tonight.... Anyhow, boards look great, I cannot wait to incorporate some art next time.
morgan
Very nice!
Nice boards! Glad you posted this, otherwise I would've missed the After Dark option at OSHpark :)
I was at the Embedded.fm picnic over the weekend and heard several exclamations of "OSHParks new waaaaah?" while showing these off.
#SOICbite Programming/Debug Connector Footprint in the wild! How exciting. The board really looks great!
Indeed! And for the most part that portion of the bring up worked fine. I was able to flash the ESP32 with no issues (even connected the clip right way around on first try!) In hindsight I may have broken out the wrong power pins, still pondering that but will detail in another post hopefully later today.
