Welp
got new boards that don't work
- Switch footprints are wrong. The two pins the switch contacts are wired to be across are actually common with each other.
- The relay footprints are wrong. The way it's wired has the switch where the coil is and vice versa. My fuckup on the schematic symbol.
- After bodging the relay problem, the 3.3V regulator drops out for some reason, only giving like 2V
- Also the auto-reset circuitry doesn't work.
Time to test and redesign, wheeeee
