The third prototype printed successfully.
I had to dissolve support overnight.
The resolution is still pretty terrible, but it'll work. I just have to do a bunch of post processing.
Lots of sanding:
More sanding of the interior surfaces needs to be done.
I need to buy wire of the correct gauge and quality, superglue and I need to print off the lens templates (forgot again while I was at work!)
Then I can assemble the model.
