The large mica samples came in, and they are beautiful.
Keep in mind that 10 of the V-1 mica costs $60 where the same size and number of V-5 Quality costs only $15. I'll compare the two.
And linear polarization film.
Here is the V5 mica, it is very clear actually although a little darker than the V1 and it feels... heavier and thicker. But samples vary, so that might not be universally true.
Make a sandwich and....
Ooooh, double polarized.
Single polarized sheet and V5 mica. Not as impressive but enhances curious things, the sky and highlights.... More restrained but beautiful all the same.
The V5 has spots or something, definitely darker. It seems to work just the same and does fine overall and is much cheaper, I don't feel bad bending this stuff and whatnot.
The V1 is stunning, so clear yet it reflects light like a mirror too, you can see the window behind me! Incredible stuff. But at $60 for ten..... You make the call.
Size of sheet next to some glasses.
Single V5.
Polarizer then V5 single.
Polarized sandwich, V5 mica in the center.
The first frame test print is coming along....
And a video to top off the experience:
