Outside / In is a multi disciplinary installation piece that uses networked IP camera systems and web based platforms to probe our perceptions of visual ambiguity and explore moments of simultaneity experienced by visitors to the gallery.
Located inside each of the nodes is a camera system that observes the periphery of the project space and the view immediately perpendicular to it. Transmitted over the local wifi network these image streams are viewed simultaneously on a monitor mounted to the wall of the space.
