Laser Cut Design
Sent off the design to get cut in 3 mm Acrylic. I have some acrylic glue (have not used this stuff before). The fumes are known to be carcinogenic!
Here is the final work area:
For homing, I have put 3 mm diameter holes in the far arm and in the base board to lock the home position.
I have use an "I" section for the arms. Not that worried about twist with this design. The arms are offset vertically so that the I beams can "nest". I have include 1.2 mm diameter, alignment holes for the GT2 pulley:
Note: The green outline is just to show the acrylic outline.
Hopefully I have made no serious mistakes.
Ah, I just thought of something, I have not check if the laser module will fit in-between the arm webs!
Not as I hoped!
Well I got back the laser cut parts. But the fit was very poor. The acrylic melts rather than vaporizes. So the I had to file the edges. During the test fit, it would go together but was very hard to get apart. I broken one of the parts. Also I glued one part upside down.
I was not keen just to reorder the wasted parts. I am looking at buying some aluminium rectangular tube instead.
I have ordered some new plastic hinges from another source (much cheaper!), I am hoping the quality is better.
So just waiting for the parts to arrive.
Not all bad!
I glued the GT2 pulleys together, not too bad:
They look a little rough but they engage the belt fine.
Alan
