FreeEEG32 prealpha2
4xAD7779ACPZ 16 kSPS,
ADR4525BRZ 2.5V REF +-0.02%,
STM32F765ZIT6 MCU 462 DMIPS
Public Chat
to produce use gerber, bom. assembly files, connect in configuration that you need.
list of pcb&pcba with components https://docs.google.com/spreadsheets/d/1kesq1XXx1iv3tl-mmWqGlSoi6JrNICaZL0DwDcNThMk/edit#gid=103632355
gerber.zip
application/zip - 745.79 kB - 06/02/2019 at 10:10
Download
assembly.zip
application/zip - 120.48 kB - 05/25/2019 at 18:59
Download
SeeedStudio BOM FreeEEG32-prealpha2 32B0H743.csv
4xAD7770ACPZ 32 kSPS, ADR4525BRZ 2.5V REF +-0.02%, STM32H743ZIT6 MCU 1027 DMIPS TFT LCD
Comma-Separated Values - 1.01 kB - 06/14/2019 at 18:30
Download
SeeedStudio BOM FreeEEG32-prealpha2 32B0F767.csv
4xAD7770ACPZ 32 kSPS, ADR4525BRZ 2.5V REF +-0.02%, STM32F767ZIT6 MCU 462 DMIPS TFT LCD
Comma-Separated Values - 1.01 kB - 06/14/2019 at 18:33
Download
SeeedStudio BOM FreeEEG32-prealpha2 32B0F765.csv
4xAD7770ACPZ 32 kSPS, ADR4525BRZ 2.5V REF +-0.02%, STM32F765ZIT6 MCU 462 DMIPS
Download
View all 8 files
  • 4 × AD7779ACPZ
  • 1 × ADR4525BRZ Power Management ICs / Voltage References
  • 1 × LSM6DS3TR
  • 1 × 47352-1001 Interconnect Products, Wire and Cable / Misc. Interconnect, Wire and Cable Products
  • 1 × CL10A475KP8NNNC Capacitors / Ceramic
View all 22 components
View all 4 project logs
Alan Green wrote 05/25/2019 at 21:50 point
It seems you hook this up to your friend's head, then program them via the STM32F7. Their body becomes your robot. Bwahahahahahaha! I guess you chose the STM32F7 because it has floating point, which means you can make your new robot's movements ultra-smooth and precise.
I'm joking. What I mean to say is... could you please add some detail in the project description so that hackaday peeps can know what this is, what it is supposed to do, and how it works?
Even some links would be a start.
Dmitry Sukhoruchkin wrote 05/25/2019 at 23:39 point
One colleague made measurement system for oil refining machines with similar configuration of ADC and MCU. But i making FreeEEG32 alpha2, and alpha is result of what was working in distinct components of prealpha. Here can be link on previous project FreeEEG32 alpha1 https://hackaday.io/project/20618-freeeeg32-32-channels-electroencephalography and in alpha2 i will fix all bugs which was found in alpha testing. Here how alpha2 can looks like https://github.com/neuroidss/FreeEEG32-alpha2/tree/master/KiCad/out/3d
Dmitry Sukhoruchkin wrote 05/26/2019 at 09:46 point
on base of FreeEEG32 prealpha2 can be organized course of assembling on its base -- brain-computer interfaces
