** I am going to merge two of my projects together: CV on wave pattern and Mini Wave Tank Micro-controller. The reason for that is I am thinking about comparing data from these two systems and try to find some correlations. Next week I will talk more about what I am planning to compare.
So ... Here's an update on my Micro Controller Data Collection System:
- (If you don't like hardware or circuits, don't worry, the project is still mainly about computer vision.)
Controller: Arduino UNO R3
1 Inverting Op-Amp circuit:
(I'm too lazy to add another power supply to the op-amp so I ended up using lots of resistors to produce the appropriate voltage)
1 Wave Probe
Sample Output (find my Python and Arduino programs in the Files section):
(I will keep updating my programs, adding more functions and simplifying the algorithm)
