Portal Fluid
Truncated icosahedron "ball" with RGB LEDs for Portal Fluid animation.
I am big fan of Rick and Morty series so I decided to built a realistic replica of Rick’s Portal Gun. It is crucial part of costume for cosplay competition which I would like to attend.
The Portal Gun must be realistic as possible. It has to have control button for dimension selection, red alphanumeric display, green diodes on the front, but most important is the portal fluid vial which makes the interdimensional travel possible.
I have thoroughly searched the internet and find some solutions for portal fluid imitation. Borax green slime, green bouncy ball floating in silicone oil or whirlpool created by running ventilator immersed in stearate glycol. None of these variants was satisfying enough.
All and all I decided to create the portal fluid using a flexible PCB.
Requirements
  • The PCB has to be an approximation of ball with as many faces as possible
  • The final outer diameter of the ball has to be at most 20 mm
  • The ball has to run from Li-ion battery voltage 4,2 .. 3,0 V
  • The unfolded PCB dimensions should fit within 50 mm x 50 mm square space for less expensive manufacturing
Description
  • The portal fluid ball consist of flex PCB folded into truncated icosahedron. The same structure which has the soccer ball. There is one RGB LED on every face of the polyhedron. The polyhedron has 32 faces which is enough to create illusion of moving light around the ball of portal fluid.
LEDs
I have found the smallest RGB LED - APA102 in 2020 package. In comparison the SK6812 LED has simpler wiring, but it has too large package for my project.
PCB
PCB is intended to be fully flexible dual layer. The PCB will be mounted on 3D printed support structure. Vias are located in non flexing area. On each of five arms there is non covered flap, which mates with other arm. These flaps are intended to be connected by solder and mechanically fasten the polyhedron. On two dead ends of each arm there are flaps without uncovered wire. These flaps should be held down by neighbour arm. It is kind of interlocking structure. These interlocking flaps were missing on my first paper model.
Connection of the whole polyhedron to external circuits is made by soldering pads on the root pentagon. Vcc and GND are located on different sides of the PCB, thus the Vcc cable has to pass through the hole in root pentagon. Data line pads are located on outside of the polyhedron.
Truncated_ikosahedron.svg
truncated icosahedron net design. From simple pentagon and hexagon net on the bottom to net with cutouts and miller layer margins on top.
svg+xml - 160.27 kB - 05/29/2019 at 23:03
Preview
  • First paper model
    pavel.vitvar05/29/2019 at 23:22 0 comments
    The net with margins was outlined without mistakes. I have found that there are missing flaps to fasten each branch of the net to each other.
View project log
Gerben wrote 05/30/2019 at 12:27 point
wubba lubba dub dub.
I like it!
