I was unable to correctly do the 3D geometry when designing the PCB. Attempts to solder and assemble the sculpture lead to over heating the castellated edges. The de-laminated pads lead to throwing away the design. It was a critical failure in the project.
![Failed Soldering Failed Soldering](https://cdn.hackaday.io/images/4691491565308553516.jpg)
