The next revision of this project will focus on the following points.
- I will use a regular polyhedron as a design point, likely a tetrahedron (4 sided die).
- This will simplify the side design and the jig design.
Initially this project was designed to compete in the beautiful hardware competition, but since the contest is coming to a close next week I will not be able to redesign and have everything manufactured in time. I will still keep this project in mind and will post again once it has made noticeable progress.
Ian Shannon Weber
