a 6 x 6 LED matrix on flex PCB
The idea is to bend this to a cylinder for a hexagonal LED sculpture. The base would be a standard PCB with a hole to mount it on a base plate with a wood cylinder and then solder the flex PCB contacts for the LED rows and columns to the base PCB.
Zip Archive - 269.35 kB - 05/29/2019 at 07:50
Yes, delete it Cancel
You are about to report the project "flex hex", please tell us the reason.
