Assembled the heating clips , isolation, parts of the housing and testet the electronics. The sidepanel with the controller will be changed to a smaller one in the next building session. The solution with one Controller plus SSR will also be replaced with two controllers only and their internal relais. See the MIRO Page for details: https://miro.com/app/board/o9J_kpTbPsU=/
