Hackaday.io Hackaday.io
Sign up Log in
BQ25703A Programmable Regulator Module
Buck boost regulator module that supports 3.5V-24V input, charging 1-4 cell batteries, and programmable output from 4.48V to 20.8V
alex-klimajAlex Klimaj
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
2.3k views
0 comments
17 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
2.3k
0
17
15
Team (1)
  • alex-klimajAlex Klimaj
Join this project's team
  • Hardware
hardware
ongoing project
Regulator programmable power module USB PD 2019hackadayprize
Related lists
Power Module
Power Module
This project was created on 05/30/2019 and last updated 7 years ago.
Description
This small module incorporates everything needed for the TI BQ25703A programmable regulator.
This is the same regulator I used in LiPow.
[http://www.ti.com/product/BQ25703A](http://www.ti.com/product/BQ25703A)
### Some key features
- Charge 1 to 4 Cell Batteries From Wide Range of Input Sources
- 3.5V to 24V Input Operating Voltage
- I2C Programmable
- Output 4.48V to 20.8V in OTG Mode Compatible With USB PD Output 1.024V to 19.2V in Battery Charging Mode
- Output Current Limit up to 6.35A
- Thermal Shutdown Input, System, Battery Overvoltage Protection, MOSFET Inductor Overcurrent Protection
- Charge Any Battery Chemistry: Li+, LiFePO4, NiCd, NiMH, Lead Acid
- Currently, I have a driver in LiPow for this regulator. I will be improving on it and making it available
Project Logs
Collapse
  • Fully assembled, tested, and up for sale!
    Alex Klimaj • 09/17/2019 at 18:36 • 0 comments
    I have finished assembling and testing the modules. They are now for sale on Tindie!
    https://www.tindie.com/products/18093/
  • Progress!
    Alex Klimaj • 09/15/2019 at 20:14 • 0 comments
    This project has been sitting on the shelf for a few months now. PCBs arrived and I got very busy with client work. I've finally got a reprieve and time to build the boards. I started building 10 units today. If all testing goes well, I will put them up for sale on Tindie.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
This is the power-management block of Manuvr’s motion-capture glove. It has been broken out as a module for testing and re-use.
Project Owner Contributor
Manuvr PowerPlant
j-ian-lindsayJ. Ian Lindsay
Power management module in a small SMT package with 4+16 ADC channels, 2A battery charger, low on resistance output MOSFET and more
bATtiny Guard - Power Management module
erikedrtechErik@EDrTech
8 - 45V Input 4.2V Regulated Output with LiPo Charger and PowerPath Management.
Volt
akbarhashakbarhash
another spare parts project
windowlicker
mattwmattw
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "BQ25703A Programmable Regulator Module", please tell us the reason.
Send message
Remove Member
