I am pure "communication system engineering" person and I have no experience thyristor, a high power semiconductor electronics device. Now we can find "thyratron" by very low price at shop because mostly vacuum tube price is supported by audio maniacs. I found 2D21 by 100JPY at vacuum tube store and this time I will try to examine how it works..
Basically thyratron is a switching device which current flow is controlled by grid voltage, as the same as thyristor by gate voltage. It's a kind of nonlinear device and no audio maniacs will need this one.
I found a good example circuit of sawtooth oscillator by 2D21, and quickly made as above. I don't have high voltage (250V, 0.1 uF) tolerance capacitor so I naively tried at anode voltage of 80V.
YES, it is working. resistor and capacitor defines time constant for the oscillation, and we can get sawtooth waveform as above!
Interesting... May be is possible to adapt it to make an audio oscillator (-2.5V to +2.5V) ?
