Hestia32 - a new chapter for HestiaPi
A project log for HestiaPi Touch - Open Smart Thermostat
Open source hardware smart thermostat for your home.
gulliverrrgulliverrr • 09/10/2026 at 11:31•0 Comments
If you've been following HestiaPi, there's a new project taking shape.
Hestia32 is the next-generation thermostat I'm developing, based on the ESP32 rather than Raspberry Pi. The goal is to keep the core HestiaPi philosophy - open hardware, open-source software, local operation and no cloud subscriptions - while creating a simpler, dedicated thermostat platform.
It features a 3.5" touchscreen, multiple HVAC relay outputs, temperature and humidity sensing, OTA updates and local integrations including Home Assistant, OpenHAB and MQTT. There will be versions for both conventional 24V HVAC systems and European 240V mains installations. Hardware is chosen wisely so that future Thread, Matter and Zigbee support is planned through firmware updates while keeping the same board.
The hardware and software are being developed openly, and the project is now getting close to production.
I've also launched the **Crowd Supply pre-launch page**. If you'd like to follow the project and get notified when the campaign launches, you can sign up here:
https://www.crowdsupply.com/makeopenstuff/hestia32
The new Hestia32 project page on Hackadayr is here:
https://hackaday.io/project/206638-hestia32-open-source-smart-thermostat
HestiaPi has been around for many years, and Hestia32 is its next chapter.
