Code for this project can be found on github. https://github.com/tehmantra/proofing_box
Temperature controlled proofing box for dough/bread.
This is a working proof of concept for the proofing box.
Everything is working, and the 14W heater provides enough heat to get the box up to 25 degrees easily.
Next steps:
- Solder to permaproto board.
- Move electionics to a small plastic box.
- Add a transformer so that it doesn't require 2 power sockets.
hi! Nice setup. But it looks like you are measuring the temperature very close to the heating element. What is the temperature gradient inside the box? I was thinking of placing a thermistor at the top and one at the bottom, or is that too overkill?
