So this week I've soldered the low-voltage side of the SparkFun converter board 'onto' the Raspberry Pi. I've let four long leads run freely from the high-voltage side of the board that can be pushed into the pins of the Psion top slot (breadboard-style!)
I've put the connections so far into a table. Now I need to put a fresh Raspbian Lite on the Pi and try to work out how to 'use' the Psion top slot. I believe it has 3 general purpose pins that can be read and written to using some kind of machine code. This page is proving very interesting https://www.jaapsch.net/psion/topslot.htm#p16.
Pi | Logic level converter (low voltage side) | Logic level converter (high voltage side) | Psion Top Slot |
Pin 1 (3.3V) | Low Voltage reference (LV) | High Voltage reference (HV) | Pin 13 (5V) |
Pin 6 (Ground) | Ground (GND) | Ground (GND) | Pin 9 (Ground) |
Pin 10 (GPIO15) | Low Voltage 1 (LV1) | High Voltage 1 (HV1) | Pin 15 (SOE)? TBC |
Pin 8 (GPIO14) | Low Voltage 4 (LV4) | High Voltage 4 (HV4) | Pin 16 (SMR)? TBC |
