A combination of some theoretical ranting and an actual project. In this project I wanted to test a form of debugging which merely records the system state and then enables one to replay it in an offline environment.
In this lab I wanted to test an idea I've had for some time, given a system with an initial state and then also given its input in a time series the end state of the system should be known. By storing the inputs in a sufficiently high resolution and asserting that the input values recorded are identical to the input values actually presented to the system, it should be possible to replay the scenario step by step, making observations along the way. When doing some programming it is often not a good idea to use a debugger even if one is present. In real-time systems, timing often gets skewed and the only thing one can do is watch the state of the system at the break point, assuming that when hitting "continue" or similar we are almost certain to get bitten by "heisenbugs", i.e. bugs that either never manifests themselves in the debugger or only does manifest themselves in the debugger.
junkotron
