Build a Passive Energy Efficient house
To date 44 videos from the Foundations up. stay tuned for the finished build
Public Chat
Passive house building/ the Future NOW / and Climate Change
This is the first Passive house / Port Alberni in the Heart of Vancouver Island, British Columbia
A 1080 sq ft Rancher wheel chair accessible. built to the Passive code
Foundation are 3ft 915mm by 8in 203mm with 30in 762mm by 8in 203mm walls, insulation under the
Concrete pad R 50. wall plates are double sealed to the wall head and caulked, no air leakage
Walls are double 2*4 51mm by 102mm @ 20 in 508mm thick insulated to R 80 with rockwool,
Plywood sheating on the  outside, with air barrier, moisture barrier placed 1/3 from the interior wall.
and hung no staples to eliminate any air leakage, all wiring and others are in the  cavity . no drilling
 through the studs. all electrical boxed etc sealed for air leakage. Windows re triple glazed, e-glass with argon
glass, high efficient plastic frames, wide window liners inside with concrete sills outside, as the
double framed walls are thick. has a heat ex changer for temperature control., small heat pump
for the hot water heater. Water lines are single runs, cold water in the sand, the water lines in pad
insulation. Ceiling is R 80 with a dropped ceiling for all the plastic ducting from the heat ex changer
Exterior double walls are have 5/8 in 12mm wall board, garage is double wide, over head door
 with hardy plank to the outside with air screening at wall plate. stay tune for updates
00006.MTS
Hold all support,
mpeg-tts - 33.56 MB - 06/06/2019 at 20:23
Download
00000.MTS
Thick walls concrete sills will not cup like wood
mpeg-tts - 45.00 MB - 06/06/2019 at 20:18
Download
00003.MTS
Double walls
mpeg-tts - 34.59 MB - 06/06/2019 at 20:14
Download
089.MTS
Finish the concrete pad
mpeg-tts - 22.03 MB - 06/06/2019 at 20:12
Download
016.MTS
Insulation at the pad sealing around the and water lines
mpeg-tts - 30.00 MB - 06/06/2019 at 20:10
Download
View all 6 files
  • 1 × material used for passive build 2*4 KD Spruce studs, double walls, rockwool innsulation, plywood sheating, trusses, duroids,
  • 1 × Eu heat ex changer will regulate the temperature, small heat pump to heat water
View all 2 project logs
View all instructions
shub59787 wrote 07/20/2023 at 13:12 point
Creating a passive energy-efficient house is essential for a sustainable future. By incorporating eco-friendly materials and smart design, homeowners can significantly reduce their energy consumption. If you're in real estate washington nc , realtors can guide you through finding or building such a house to lower your environmental impact and enjoy long-term cost savings.
