I think I have perfected the technique of soldering those angled headers now — after assembling a few more.
The speaker on GPIO02 makes some cool sounds on boot — because that's the debug serial output pin.
For completeness, here is the firmware for the attiny24:
#include "USI_TWI_Slave/USI_TWI_Slave.c"
#define PINS_COUNT 6
#define RST_PIN 10
#define I2C_ADDRESS 0x10
const uint8_t pins[PINS_COUNT] = {0, 1, 2, 3, 7, 8};
volatile bool clear = false;
volatile uint8_t buttons = 0;
void request() {
USI_TWI_Transmit_Byte(buttons);
clear = true;
void setup() {
pinMode(RST_PIN, OUTPUT);
digitalWrite(RST_PIN, HIGH);
for (uint8_t i = 0; i < PINS_COUNT; ++i) {
pinMode(pins[i], INPUT_PULLUP);
USI_TWI_Slave_Initialise(I2C_ADDRESS);
USI_TWI_On_Slave_Transmit = request;
delay(50);
digitalWrite(RST_PIN, LOW);
delay(50);
void loop() {
static uint8_t last_buttons = 0;
uint8_t current_buttons = 0;
current_buttons <<= 1;
current_buttons |= !digitalRead(pins[i]);
if (clear) {
clear = false;
buttons = 0;
buttons |= last_buttons & current_buttons;
last_buttons = current_buttons;
delay(16);
}Nothing complicated, really — I'm using the USI example from the Atmel application note here, keeping everything in the main loop, so as to not block or delay the interrupts.
Lastly, I wonder if I should work on the thickness of the whole thing, or just stuff a lipo in there:
deʃhipu
