3D modelling
A project log for Wall-E
A small-size, low-cost, Wall-E robot. Remote controlled from a HTML5 interface, through WiFi websockets.
etienneEtienne • 06/10/2019 at 19:53•0 Comments
At first, I thought I would only power the treads, and keep head & arms static. I launched Skecthup and started drawing the sides of the torso. I imported a detailed model from the 3D warehouse, scaled it down to match roughly the scale imposed by the off-the-sheld tracks; then simplified the design.
Then I started playing around with models of small servo... and was quickly convinced that it's possible to add servos inside the arms and neck without sacrificing the overall Wall-E look.
