I promised, but I write late. Sorry guys.
Project log:
3. dynamic memory allocator in SDRAM (for heap) - done
4. supporting FAT32 - done
5.1. fs utils: cat - done
And... Try to work with LTDC, but need to read the documentation before PCB tracing))
RM68120 works with 4 modes:
- 8 bit DBI (parallel 80 bus IF for pixel data and conf), CS/WR/RD/CD
- 16 bit DBI
- 24 bit DBI
- 24 bit DPI (RGB IF for pixel data and SPI for conf) PCLK/HSYNC/VSYNC/DE (can be configured in 16/18 color mode with gaps in connection on color bus: Page 72)
Mode configurating by h/w jumers IM0/IM1.
After some h/w upgrades:
LCD runned, but:no red color in picture! because DPI mode needs gaps in connection on color bus)
I am planning to use FPGA to fix it issue, but maybe some later (need to done FPGA NAND flasher at first).
And the worst - the frame rate is low (but maybe using of FPGA will fix it same)
At the end, latest console scr =)Config of LTDC done.
Next step - trying to use FPGA to fix color issue. Coming soon =)
Vasilii Chumakov
Looks great!
