LCD trobles
A project log for Redphone
The Redphone project is an open source mobile phone
vasilii-chumakovVasilii Chumakov • 07/15/2019 at 20:16•1 Comment
I promised, but I write late. Sorry guys.
Project log:
3. dynamic memory allocator in SDRAM (for heap) - done
4. supporting FAT32 - done
5.1. fs utils: cat - done
And... Try to work with LTDC, but need to read the documentation before PCB tracing))
RM68120 works with 4 modes:
Mode configurating by h/w jumers IM0/IM1.
After some h/w upgrades:
LCD runned, but:no red color in picture! because DPI mode needs gaps in connection on color bus)
I am planning to use FPGA to fix it issue, but maybe some later (need to done FPGA NAND flasher at first).
And the worst - the frame rate is low (but maybe using of FPGA will fix it same)
At the end, latest console scr =)
Config of LTDC done.
Next step - trying to use FPGA to fix color issue. Coming soon =)
colton.baldridge wrote 07/16/2019 at 12:52 • point
Looks great!
