Design Requirements
- Camera is configured as a web client
- Deploy and cloud server to maintain connection with camera modules perform image processing
- Use computer vision techniques to detect and classify faces seen in camera feeds
- Cameras track face movements using mounted servo system
- Alert is sent if the person’s face is not recognized
Design Description
Figure: Block diagram of proposed multi-camera system with central cloud server
Using a hub and spoke model will result in a high latency between sensors and actuators, because a TCP round-trip will be required to process each video frame.
The benefit to this is that the central server is capable of higher image processing loads. We will use a combination of Tornado, a lightweight python web server, and OpenCV, a powerful real-time computer vision library built on python, to our advantage on the cloud compute instance. This will allow the viewing and autonomous control of multiple video feeds..
Planning and Organization
Action by | Start Date | End Date | Status | |
Define project goals | Nat | Apr 2, 2019 | Apr 9, 2019 | Complete |
Research components | QK | Apr 2, 2019 | Apr 9, 2019 | Complete |
Prepare order | Nat | Apr 2, 2019 | Apr 9, 2019 | Complete |
Create new PCB layout | QK | Apr 9, 2019 | Apr 11, 2019 | Active |
Setup Amazon AWS services | Nat | Apr 9, 2019 | Apr 16, 2019 | Complete |
Camera client sends images to AWS | Nat | Apr 16, 2019 | Apr 23, 2019 | Active |
Use breakout board to test LCD&Pan-tilt | QK | Apr 17, 2019 | Apr 24, 2019 | Upcoming |
Put together breakout prototype | QK | Apr 18, 2019 | Apr 25, 2019 | Upcoming |
AWS server processes images with CV | Nat | Apr 23, 2019 | May 9, 2019 | Upcoming |
Make revisions and make embedded PCB | QK | Apr 25, 2019 | May 2, 2019 | Upcoming |
Put together embedded prototype | QK | May 9, 2019 | May 16, 2019 | Upcoming |
Make revisions and design revised PCB | QK | May 16, 2019 | May 23, 2019 | Upcoming |
Pan-tilt base reacts to location of human face | Nat | May 9, 2019 | May 30, 2019 | Upcoming |
Put together final prototype | All | May 30, 2019 | Jun 12, 2019 | Upcoming |
Prepare final presentation | All | Jun 4, 2019 | Jun 12, 2019 | Upcoming |
Figure: Gantt Chart for the project
Item Desc. | Mfg. Part # | Unit Price | 1000 Unit Price | Quantity |
Mini Pan-Tilt Kit | 1967 | 18.95 | 15.15 | 1 |
LCD screen | 181 | 9.95 | 7.96 | 1 |
Figure: Bill of Materials for the project
Splitting of work
Qiankai will largely focus on the hardware aspects of the design and fabrication process, including PCB design, servo motor control and final integration of different modules.
Nathaniel will design the central server functionality, modify the camera to accept wifi connections to the server and stream images, and implement computer vision techniques.
Results of Market Research
Based on home ownership data, about 40 million middle to upper income urban households own their properties globally, and many of these households face the real threat of petty household theft. To that end, they may find value in an autonomous visual security system that deters thieves while providing homeowners of critical alerts and valuable visual evidence of trespassers.
List of competitors
One major brand is SimpliSafe, which provides an array of household security camera products, entry sensors and motion sensors. At a price of US$500 for a complete solution, this may be prohibitive for even that most security-conscious of users. The products also do not include face detection and recognition
NestCam is another serious competitor that features built-in facial recognition for outdoor cameras, and is able to recognize ‘familiar persons’ with in-app alerts. Cloud storage backs up the video feeds as part of the product package. The camera retails for $349, a hefty price tag for a singular camera, or $600 for a pair.
Other brands: Arlo, Allianca, Blink, Nest Cam, Zmodo, Dlink, Netgear, Logitech
Results of Interviews
We conducted interviews with two potential users, but did not manage to interview an expert. Our interviewees found a product that could recognize specific faces to be very useful in monitoring their private spaces, for example, alerting against front door package thieves or trespassers. On the topic of facial recognition, one interviewee noted that constant face detection alerts could get stale because of false alarms, and suggested using criminal face databases to reduce false alarms
Next Steps
Through signal generator, we have found that duty cycle of square wave stands for position, and 1% duty cycle corresponds to 25 degree. Some parameters are included here, period of 20 ms, amplitude of 3.3 Vpp. Moreover, two axises of motors are controlled by two different channels, we will have to generate two relative signal to control the facing direction of pan-tilt kit. By the next presentation, we hope to provide a working demonstration of the servo motors through PWM signal generated by MCU. Our final goal is to receive facial recognition information from webcam, and move motor to right position as we plan at the same time.
Another aim is to have a fully working camera module that streams images to the server at a reasonable rate, of at least one every two seconds. Should this not work, one contingency is to use lower resolution images or revamp the TCP protocol used to make it more efficient.
Finally, as a stretch goal we will attempt to demonstrate an initial prototype of the facial classifier that generically classifies faces seen on the camera’s image stream.
References
https://www.cnet.com/pictures/security-cameras-with-facial-recognition-tech-inside/
Nathaniel Wong
