The top cover required some Dremel job to accomodate to eliminate an interference with the recessed base of the pushbutton cap.
But then if fitted very well.
The height of the shaft above the top cover is about 10mm, just enough to tighten the screw of the knob I am using.
And that's it!! Another completed project!
