ESP32 as BT receiver with DSP-capabilities
Adding features such as biquad filters to espressif's a2dp_sink example.
I'm trying to build an advanced BT receiver for mobile speakers based on the ESP32 and a PCM5102 DAC. So far biquad filters and a startup sound are implemented.
Code-base is espressif's a2dp_sink example: https://github.com/espressif/esp-idf/tree/master/examples/bluetooth/a2dp_sink
Unfortunately I still did not have much time to document the project properly. However if you are a bit familiar with the ESP32 and ESP-IDF, you should get along with the instructions :)
  • 1 × ESP32 Microcontroller
  • 1 × PCM5102 Data Converters / Digital to Analog Converters (DACs)
  • ToDo
    Raphael H06/22/2019 at 20:06 0 comments
    - Add a more easy/clean way to add biquad filters
    - Better/more detailed instructions
    - Audio processing for startup sound
    - More efficient way to store startup-sound (mono, maybe lower samplerate?, maybe only 8Bit?)
    - Other functions for a mobile speaker, e.g. battery watchdog
View project log
  • 1
    Setting up the hardware
    To build your own bluetooth-receiver you only need an ESP32 and a PCM5102 DAC.
    I soldered the DAC directly to the ESP32 but you could also use a breakout board. The a2dp_sink uses the following pins at default:
    ESP PinI2S Signal
    GPIO22 LRCK
    GPIO25DATA
    GPIO26BCK
    However I changed the setup the following, since I will solder the DAC directly to the ESP32:
    ESP PinI2S SignalPCM5102 Pin
    GPIO15LRCKLRCK
    GPIO2DATADIN
    GPIO4BCKBCK
    GNDGND
    3V3VIN
    Now you can remove the RX2 Pin from the ESP32 since we wont give the DAC a SCK. It will generate this clock from the other clocks we are providing. I put a little tape strip over the connection to prevent it from short circuiting if the pin is used for other stuff. You also have to solder the sck bridge on the front of the DAC. Afterwards you can put the DAC directly under the ESP32 like this:
    Now you can solder the pins together:
    Now the hardware is prepared succesfully.
  • 2
    Setting up your project on the PC
    First you need to install the ESP-IDF as described here: https://docs.espressif.com/projects/esp-idf/en/latest/get-started/
    Afterwards you can copy the folder \examples\bluetooth\a2dp_sink\ to your project home directory. Change your path in msys to the copied folder using "cd .....". With the command "make menuconfig" you can start the setup. Here you have to change the pins in the a2dp_sink expample configuration to the pins you connected to the DAC:
    You also have to set the right COM port in the serial flasher configuration. Safe the configuration and exit the menuconfig.
    Afterwards you can connect the ESP32 to your PC and test if everything is working. To try this you have to use the command "make flash". After the flashing is competed you can find a a2dp sink bluetooth device. After you paired our device to it you can start playing some audio, you should hear it if you connect your headphones to the DAC.
  • 3
    Add your own audio processing
    Open main\bt_app_av.c
    Replace the function void bt_app_a2d_data_cb(const uint8_t *data, uint32_t len) with the following code:
        size_t bytes_written;
        uint8_t *mydat = malloc(len);
        if(mydat == NULL)
            ESP_LOGI(BT_AV_TAG, "Not enough memory available");
        else
            for (uint32_t i = 0; i < len; i+=4)
                sample_l_int = (int16_t)((*(data + i + 1) << 8) | *(data + i));
                sample_r_int = (int16_t)((*(data + i + 3) << 8) | *(data + i +2));
                sample_l_float = (float)sample_l_int / 0x8000;
                sample_r_float = (float)sample_r_float / 0x8000;
                in = (sample_l_float + sample_r_float) / 2.0f;
                //Audio processing Left Channel
                //HP 130Hz
                out = in * (0.9869865272227986f) + biquad1_z1;        //out = in * a0 + z1;
                biquad1_z1 = in * (-1.9739730544455971f) + biquad1_z2 - (-1.9738037472862642f) * out;    //z1 = in * a1 + z2 - b1 * out;
                biquad1_z2 = in * (0.9869865272227986f) - (0.9741423616049301f) * out;        //z2 = in * a2 - b2 * out;
                //Peak Fc 10095, Q 0.478, 6dB Gain
                out2 = out * (1.5066355805385152f) + biquad5_z1;        //out = in * a0 + z1;
                biquad5_z1 = out * ( -0.12972459720746804f) + biquad5_z2 - (-0.12972459720746804f) * out2;    //z1 = in * a1 + z2 - b1 * out;
                biquad5_z2 = out * (-0.5247301530319133f) - (-0.018094572493397725f) * out2;        //z2 = in * a2 - b2 * out;
                out = out2 * 0.4f;
                //End of audio processing
                int32_t a;
                a = floor(32768 * out);
                if (a>32767) {a = 32767;}
                if (a<-32768) {a = -32768;}
                sample_l_int = (int16_t)a;
                *(mydat + i + 1) = (uint8_t) ((sample_l_int >> 8) & 0xFF);
                *(mydat + i) = (uint8_t) (0xFF & sample_l_int);
                //end of left Channel
                //Audio processing Right Channel
                //HP 50Hz 1 Q=0.54119610
                out = in * (0.993448957683901f) + biquad3_z1;        //out = in * a0 + z1;
                biquad3_z1 = in * (-1.986897915367802f) + biquad3_z2 - (-1.9868727071697347f) * out;    //z1 = in * a1 + z2 - b1 * out;
                biquad3_z2 = in * (0.993448957683901f) - (0.9869231235658689f) * out;        //z2 = in * a2 - b2 * out;
                //HP50Hz 2 Q=1.306563
                out2 = out * ( 0.9972686246697485f) + biquad4_z1;        //out = in * a0 + z1;
                biquad4_z1 = out * (-1.994537249339497f) + biquad4_z2 - (-1.9945119442195687f) * out2;    //z1 = in * a1 + z2 - b1 * out;
                biquad4_z2 = out * (0.9972686246697485f) - (0.9945625544594253f) * out2;        //z2 = in * a2 - b2 * out;
                //LP 130Hz
                out = out2 * (0.00008465357966651423f) + biquad2_z1;        //out = in * a0 + z1;
                biquad2_z1 = out2 * (0.00016930715933302846f) + biquad2_z2 - (-1.9738037472862642f) * out;    //z1 = in * a1 + z2 - b1 * out;
                biquad2_z2 = out2 * (0.00008465357966651423f) - (0.9741423616049301f) * out;        //z2 = in * a2 - b2 * out;
                out = out * 1.0f;
                sample_r_int = (int16_t)a;
                *(mydat + i + 3) = (uint8_t) ((sample_r_int >> 8) & 0xFF);
                *(mydat + i + 2) = (uint8_t) (0xFF & sample_r_int);
                //end of right Channel
            i2s_write(0, mydat, len, &bytes_written, portMAX_DELAY);
            free (mydat);
        if (++s_pkt_cnt % 100 == 0) {
            ESP_LOGI(BT_AV_TAG, "Audio packet count %u", s_pkt_cnt);
            ESP_LOGI(BT_AV_TAG, "Process task core: %u\n", xPortGetCoreID());
    Furthermore you need these additional global variables:
    static int16_t sample_l_int = 0;
    static int16_t sample_r_int = 0;
    static float sample_l_float = 0.0f;
    static float sample_r_float = 0.0f;
    static float in = 0.0f;
    static float out = 0.0f;
    static float out2 = 0.0f;
    static float biquad1_z1 = 0.0f;
    static float biquad1_z2 = 0.0f;
    static float biquad2_z1 = 0.0f;
    static float biquad2_z2 = 0.0f;
    static float biquad3_z1 = 0.0f;
    static float biquad3_z2 = 0.0f;
    static float biquad4_z1 = 0.0f;
    static float biquad4_z2 = 0.0f;
    static float biquad5_z1 = 0.0f;
    static float biquad5_z2 = 0.0f;
    You can change the coefficients of the biquad filters to design them as you like. Here is a link to a nice coefficient-generator: Earlevel engineering Biquad Calculator V2
    You can also add more biquad-filters or even add your own algorythms. I did not have the time yet to make the code more easy to add/edit the filters. And I still have to test how many biquads filter calculations the ESP32 can handle. Maybe it is even possible to make use of the second core for the audio processing....
View all 4 instructions
Rich text editor
Hien Van To wrote 11/04/2023 at 06:11 point
Your project is superb. I'm doing my Bluetooth speaker and I'm stuck at this EQ stuff and your post is a lifesaver. I created this Hackaday account to say thank you for this post.
Rodrigo Bistolfi wrote 03/11/2023 at 01:45 point
Hey, link to code seems to be broken. Great project!
