I have a lot of ideas for expansion to make sure there is room for easily exercising your creativity. But I need to narrow things down and get a produceable design ready.
What do you think of these as baseline features that would be included?
- 64 bits of authentic core memory (weave it yourself)
- 64 RGB LEDs (Pimoroni Unicorn Hat)
- 4 hall switches (user configurable)
- Arduino compatible Teensy 3.2 (32-bit NXP Cortex-M4 72 MHz) with all IO accessible
- Magnetic Stylus with narrow and wide field tips
- 4x "AAA" battery pack holder
- Battery Voltage Monitor
- All of the matrix drive lines, the power rails, and the sense outputs will be easily accessible
What do you think of these plans to provide the following header rows/pads for additional expansion?
- Generic I2C OLED
- Generic SPI OLED or Sparkfun Teensy View SPI OLED
- SAO Port, quantity 2
- Adafruit MicroSD breakout board
- Sparkfun QWIIC port
- Ambient Light Sensor
- Proximity Sensor
- Sparkfun LiPo manager
- Generic or Adafruit 3.2" LCD to replace LED Array
What would you consider the must-haves?
Any ideas for nice-to-haves?
If you wouldn't mind providing that feedback through the survey form on my website, I'd appreciate it:
Andy Geppert
