Today we wen't through the code we worked on so far and decided to use Cecilia's code.
A notable occurrence:
TranslatorBlockFactory.java contains the path for some blocks.
block-mapping.properties contains most of the paths for the rest of the blocks. It's only necessary to alter one of the files, though currently we have both altered.
We uploaded to a github project and created a couple new branches. From here on out we will be working on separate new functions and merging them once completed.
