Finally got the kernel module ported over for the SN65DSI86. Added the Innolux N173HCE-E31 panel added to the kernel as well and updated the device tree files to enable the bridge kernel driver. Need to create the pwm controller code for the bridge driver. Will probably work on the mechanical model a bit more before doing any other software stuff at this point.
John Basista
