Two units went online in Norway, the 11000016 in Oslo, and the 11000013 in Sandefjord.
The measurements show higher readings compared to the tests performed in Timisoara:
The Northern Europe seems to have a relatively higher background radiation. Here is a map that shows some of the background radiation levels measured across parts of Europe. Much of this is due to the radon:
Source and more details, here.
