To make things simpler when mounting uRADMonitor outdoors, here is a plastic enclosure that is rainproof when the case is mounted in vertical position, with the cables at the bottom:
The radiation detector circuit board is safely mounted inside.
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
